Help finding a breast morph(?
Dogoman
Dogoman
The iV Squish Morphs have one that can push them together to eliminate the cleavage if that is what you mean.
Also I have seen some clothing items that come with similar special morphs. For instance outfit at Renderosity called Oktoberfest Waitress.
If you mean have the edge of the corset "cut into" the breast and depress the flesh a bit, perhaps the clothing parameters could be tweaked with something like Fit Control? It has a bunch of smoothing sliders for the breast area, but not sure if it would work. (I've only used them to slightly enlarge clothing over breasts to avoid poke-through, but maybe it could work in reverse?)
Or maybe a tiny negative Push Modifer on the corset?
Maybe if you moved this post to The Commons or Technical Help subforums you might get more suggestions.
for the effect between the corset and the breast you just have to change the displacement map, search on google "stockings for Geoshell G3F/G8F" on devientart to see an example
