Creating property shortcut
I use facial expressions a lot. Currently they are under "Pose Controls\Head\Expressions\ProductName", is there a way to create some kind of shortcut that will be opening that property group? A key shortcut or maybe a different property that will be right under the figure itself without having to go deep. Or maybe some other solution to open them faster?
I know I can move all those properties but that's not really an ideal solution.
  • Richard HaseltineRichard Haseltine Posts: 111,430
    You could click the heart icon on the slider to add them to the Favourites group. If you do that save a new character preest for loading the figure as the change doesn't affect the base assets. You can also simply edit the grouping - click the gear icon on the slider>Parameter Settings and edit the path; again,save a new character preset to load this modified version.
