Help - blocky Genesis 2 figure while posing
First of all, sorry if I've described this wrong but I don't know the 'proper' snappy words.
So I'm trying to pose the fine details of a G2F figure.
I use the parameter dials as I find I can fine control those better.
The problem is, as soon as I spin a dial, the mesh 'simplifies' into something lower res and blockier looking.
As soon as I let go of the dial, it reverts back to hires.
This is driving me mad as it makes fine posing to stop body parts sticking through the floor, etc., a nightmare.
Is this how G2 always was?
Is there an option I can swap to stop it happening? A secret hidden option, maybe?
Please help, you're my only hope...
  • NorthOf45NorthOf45 Posts: 5,915
    Not secret, but not obvious. The Manipulation Draw style might be set to Solid Bounding Box. Go to the Draw Settings tab (open it from the Menu -> Window -> Panes (Tabs) if not already open) and look for Manipulation Draw Style. Click the drop-down list and select "Use Current (Off)". "Current" means the current draw style, like Texture Shaded, or whatever. The other settings might help to fine tune the response time a bit.
  • ProtozoonProtozoon Posts: 554
    edited July 2020
    It's the same with Genesis 8 too. Default is SubD 1 but while manipulating it changes to Base res to enhance viewport fluidity.
    Draw settings/General/Subdivision Updates -> Change to "Continuous".
    The viewport performance might take a hit.
    Post edited by Protozoon on
    Brilliant!
    Does exactly what I need - back to work for me - 1000 thanks
    Brilliant!
    Thank you! Now I had to think about it I will use this setting too :)
