Checking and Unchecking Scene Elements?
DekeDeke Posts: 1,636
Is there a fast way to check or uncheck items in Daz Studio? I want to make most but not all parts of a complex model invisible. I've tried a option click to select a long list but that doesn't to to then check the "eye" and make them invisible. Any suggestions?
  • fixmypcmikefixmypcmike Posts: 19,709
    Multi-select in the Scene tab, then instead of using the eye go to the Parameters tab and set Visibility to Off
    That's a good one, been there with using primitive to make a set.
    Then I want to make the entire balcony over the figure disappear, so I can position her/him...
    selecting the root primitive, and selecting "all children", then clicking an eye dose not do it.
    I have to expand the tree (clicking the triangle), and click each eye, one at a time.
    1710 x 982 - 419K
    edited June 2014
    fixmypcmike, That is So much better... Thanks!
    1703 x 978 - 506K
  • DekeDeke Posts: 1,636
    Thanks for the tip. I knew there must be a way!
