How to remove the C: from this preset
Hi,
 I am using "Content Checkup" to test a product. I keep getting this error message. All of the files are actually there and were written on the D: Drive, Copy and pasted into a testing directory on the CDrive.
Any advice on how to fix this will be GREATLY appreciated.
"Files with wrong paths or files are missing:
File: C://ProductTesting/G3-G8-Nurse/People/Genesis 8 Female/Clothing/lululee/G3-G8-CP-Nurse/IRAY/00001-GeoShells/00001-Base-Materials/Arms-Legs/001-A-Legs-White-Leather-001.duf
Path: /G3-G8-Nurse/Runtime/Textures/lululee/Genesis3-8/G3-G8-Nurse/Colors/Nur-White.jpg
The directory 'C:/ProductTesting/G3-G8-Nurse/People/Genesis 8 Female/Clothing/lululee/G3-G8-CP-Nurse/IRAY/00001-GeoShells/00001-Base-Materials/Arms-Legs/001-A-Legs-White-Leather-001.duf//G3-G8-Nurse/Runtime/Textures/lululee/Genesis3-8/G3-G8-Nurse/Colors/' does not exist!
  • HavosHavos Posts: 5,705
    Try editing the duf file and removing the "C:/ProductTesting/G3-G8-Nurse" from the front of the path. It might then work. Also remove /G3-G8-Nurse from the start of the texture path.
  • lululee1lululee1 Posts: 346
    Hi Havos,
    None of those show up in tthe preset.
    Here's the preset. Also I'm attaching a screenshot from the "ContentCheckup" pdf that shows this can happen but not how to fix it.
    Thanks so much for taking your valuable time to helpe me with this.
    Cheerio
    lululee
    txt
    txt
    001-A-Arms-White-Leather-001.txt
    176K
    Here's the info from the PDF.
    800 x 322 - 57K
  • LeanaLeana Posts: 13,616
    Looking at the error message, I'd say the problem is that your Runtime folder is not directly inside the registered DS content directory, ie that DS has "C:/ProductTesting/" as a content directory, not "C:/ProductTesting/G3-G8-Nurse/". So when you save your preset it keeps the "G3-G8-Nurse" in the path, it doesn't start at "Runtime".
    Hi Leana,
        Thanks you so much.
    I really appreciate your help.
    Cheerio
    lululee
