Technical questions about animating with Puppeteer and Powerpose
SnowSultanSnowSultan Posts: 3,845
OK, I hope I can make sense here after being stunned by recent news (can this year possibly get ANY weirder?)...
1. Is there a way to prevent Puppeteer from creating keyframes for every frame when animating between dots in real time using the Record feature? It's convienent, but just about impossible to edit the animation afterwards.
2. Is it possible to reconfigure the Powerpose dots that control head/neck movement and torso movement to create keyframes under the Head-Neck Bend/Twist/Side-Side and Waist Bend/Twist/Side-Side dials instead of making a bunch of them for each body part that they manipulate? This could also solve the issue of those same two dots not directly affecting those parameter dials, leading to some confusing moments when posing them using both methods (eyes too).
I think I had more questions, but I can't remember them now. Those two ought to be enough for tonight anyway. Thanks in advance for any help.
