PowerPose Looks Much... Uglier
Hi everyone!
Since maybe last week, my PowerPose doesn't look right anymore (I'm attaching a screenshot).
Has this happened to me only?
How can I fix it?
Thank you in advance!
560 x 949 - 37K
  • SevrinSevrin Posts: 6,314
    Hmm.  I show the template as, e.g. "Base (Genesis 8 Male).  Do you have the option to choose a different template?
  • LenioTGLenioTG Posts: 2,118
    No, I don't!
  • Richard HaseltineRichard Haseltine Posts: 111,459
    How are you installing your content? Have you changed your content directories at all?
    I'm mostly using DIM.
    Yes, I've made a mess. I had to format Windows 10, and when I linked to the previous directories on other drives no content was shown.
    So I have deleted everything, and reinstalled it all.
    But I had the same issue before the formatting.
    I have disabled many plugins, maybe that's the cause?
    Plug-ins wouldn't be the issue, I'd think, as long as the actual PowerPose plug-in was enabled. If you isntall with DIM then the Genesis 8 Female/Male PowerPose templates are separate packages, so double-check the one for the male is installed..
    That was the problem indeed: I hadn't reinstalled those two templates!
    Thank you Richard :D
