A little behind, just checking
Hello, its been a while since I've been on here, about a few years.
Until recently, I was seeing what the situation is, with DSON importer and Poser (I have version 10), with regards to using Genesis figures, especially the Victoria base figures.
So anyway, am I right in thinking that I can use G3 content only on Daz Studio (I have 4.9), with the DSON importer add on in the program? Plus anything up to G2 with Poser?
Thanks.
  • LeanaLeana Posts: 13,476
    Yes, DSON importer only supports Genesis 1 and 2.
    There are workarounds to use Genesis 3 and 8 in Poser, but IIRC some of the "fixes" involved require Poser 11.
  • WandWWandW Posts: 2,905
    edited July 2020
    ...And the DSON Importer no longer works properly in Poser 11.3 due to changes in the Python scripting language.  Exporting as a CR2 from Studio should still work in Poser 10, but as Leana notes, it is not as straightforward for G3 and 8, requiring a utility to be run on the converted cr2s.  The free utility can be gotten here: (Edit; apparently the face morphs do not work in Poser 10 for exported G8)
    https://www.renderosity.com/mod/freestuff/?item_id=76121.
    Forum thread here...
    https://www.renderosity.com/mod/forumpro/?thread_id=2900039
    Post edited by WandW on
  • RHatchRHatch Posts: 50
    If you're willing to put in the time, you can convert G3/8 face dials to morphs, which will work in Poser, including Poser 10.
