? help with Zev0 pose converter G2F to G3F forearm unlock SOLVED
DiomedeDiomede Posts: 15,466
edited July 2020 in The Commons
Google has failed me.
I am trying to find instructions on using Zev0's script to convert poses from G2F to G3F.  After conversion, I am getting a message that says to first unlock the forearms before use.  I can see a file with a related name in the scripts folder but there are no instructions on using it.  DIM's "show installed files" utility does not show a help pdf with the converter script.  Specifically, how to identify the files to be converted, location to place, order in which to use compared to main script, etc.
Searches of the forum returned a 404 cannot find for the G2F to G3F thread.
874 x 463 - 115K
746 x 876 - 80K
1261 x 404 - 120K
Post edited by Diomede on
  • DiomedeDiomede Posts: 15,466
    OK - I found a more generic support commercial thread for Pose Converter scripts.  Perhaps my answer will be there.
    https://www.daz3d.com/forums/discussion/51586/pose-builder-pose-converter-support-thread-commercial/p16
  • fastbike1fastbike1 Posts: 4,084
    edited July 2020
    @Diomede
    It is a separate script in the Scripts>Genesis 2 to Genesis 3 Pose Converter.
    651 x 617 - 53K
    Post edited by fastbike1 on
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    I am trying to find instructions on using Riversoft's script to convert poses from G2F to G3F.  After conversion, I am getting a message that says to first unlock the forearms before use.  I can see a file with a related name in the scripts folder but there are no instructions on using it.  DIM's "show installed files" utility does not show a help pdf with the converter script.  Specifically, how to identify the files to be converted, location to place, order in which to use compared to main script, etc.
    This product is Zev0's.  You might want to update the title.
    I use this product Pose Converter Genesis 2 Female(s) to Genesis 3 Female(s)
    I dislike pose converters which require I do extra steps. Sadly it seems to be gone from the store now.
    Thank you, @fastbike1, @Serene_Night, and @RiverSoftArt.
    Apologies to RiverSoftArt and Zev0.  I have updated the title and first post.
    SOLVED - I made sure the G3F figure was loaded and selected and then ran the forarm unlock script.  Not sure if it is necessary, but was sufficient.
