Light makes hair see through
Hey guys. I tried out HDR lightning. But the light makes the hair behind the figure look as if it is not there, leaving gaps. How can I avoid this? It only happens with long female hair.
Let me know if you require higher resolution or full pics, there were just quick renders to show what it looks like
298 x 308 - 25K
232 x 254 - 104K
168 x 302 - 98K
Check the Surfaces tab to make sure the hair is using an iray material. The auto conversion, from 3delight to iray, doesn't always work correctly.
If you could specify the hair you're using, might be able to figure something specific to it out.
Hey, these are Iray for sure. The hair are Jolina Hair and Fane Hair
