How to solve wall not displayed in iray rendering
preview is ok from both side like this
but when rendering,this wall is disappeared. i even add  a cube wall by myself,it still likes this
and i'm sure i have turn it on witn an HDRI light,  anybody can help??
Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 112,006
    Are you sure you don't have an Iray Section Plane sitting there?
  • cm152335cm152335 Posts: 421
    edited June 2020
    not only the wall is invisible in render, but also some props too.
    possible you put them in a "group"
    i remember i had this problem,, (in a wall)
    i was check and fixed on 'surfaces' tab around metalicity options
    Post edited by cm152335 on
  • chris-2599934chris-2599934 Posts: 1,988
    Is this a scene that you've built yourself, or something that you've acquired ready made. As Richard implies, it looks very much as though your scene includes an iray section plane, but I don't see how you could have added one accidentally.
    Take a look in the Scene tab and see if you can find one.
  • StratDragonStratDragon Posts: 3,291
    the position of the plane that is rendering is past the props. something is there, possibly embedded in the hierarchy of you scene or maybe you can find it if you show invisibles in your scene tab.
