DForce Femme Fatale Hair G8 doesn't show in Iray viewport
DefaultNameDefaultName Posts: 434
Hello. I'm trying to use this hair https://www.daz3d.com/dforce-femme-fatale-hair-for-genesis-3-and-8-females
The problem is that I can't preview what it looks like in Iray in the viewport. There must be some kind of parameter for me to switch on, but I have yet to find it. Can anyone help? Thank you.
Post edited by DefaultName on
  • felisfelis Posts: 6,523
    In the Parameters there are (2 if I remember right) settings that must be 'On'. I think the group is named Simulation > Preview.
  • DefaultNameDefaultName Posts: 434
    I've looked in the parameters tab and can't find an option like that.
    I had forgotten that you have to select the hair, not the hair cap, ie first expand the hair in the scene tab.
  • GordigGordig Posts: 10,805
    edited June 2020
    Even then, not every hair seems to have that option. I had Volta hair loaded into a scene when I saw this thread, so I looked into it, and I couldn't find that setting (“pr preview hairs”, or something to that effect) on either the scalp or the hair.
    Post edited by Gordig on
  • LeanaLeana Posts: 13,516
    edited June 2020
    Parameter is called "preview PR hair", under General > line tesselation section, and you may need to increase "viewport line tesselation sides" too.
    Post edited by Leana on
    I've tried turning that parameter on and off, still not showing.
    You also have to check that the preview line tesselation has a value above 1.
    Ah, that did it! Thank you very much.
