Sun-Sky Only
Is there a way to get Daz to allow you to add other lights also to the scene in this mode?
    AFAIK one can add primitive lights to any mode. {create a primitive, add emissions to it, etc.}
  • NorthOf45NorthOf45 Posts: 5,897
    Not directly. You need to select Dome and Scene, then remove the Environment Map (set it to None), which will force Sun-Sky as the environment. Kind of counter-intuitive, but it will now let you add scene lights.
    Okay, that happens too often...
    Yes, of course, emissives can be used any time as they aren't seen as "lights" in Studio. I was thinking about spotlights and point lights, and the like, and their use.
