Problems with install manager
Hi
I am new to daz3d. I downloaded the sirius labs environment and I am getting this issue when I try to install it.
Install Manager cannot find a required path. The package for "Sirius Labs" requires that the installed path for "Carrara 8.5, 8, 7.2, 7, 6" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
anyone able to help?
thanks
First of all, do you have Carrara : From the Product Page.
The Settings for the DAZ Install Manager (DIM) is available through the Gear icon at the top right of the interface. Then go to Applications and make sure that you have the path to your version of Carrara listed there.
I can post an image in a few minutes if that will help?
yes I do. if you could post an image that would be great.
thanks
Hope that this helps, if not, just ask.
