D-force Falls though body
Unless I use "Best" collision mode, the simulated cloth always falls through the body of my figure.
Is there any way to fix this?
  • Richard HaseltineRichard Haseltine Posts: 110,625
    Is this cloth made for dForce used on a standard Daz figure?
  • PsyckosamaPsyckosama Posts: 510
    Yes. It happens with everything. Hair, clothing, unless its best it falls right through G8F.
    I've not encoutnered this - can you give a couple of examples? Does the Bardot Dress from the dForce Starter Essentials work?
  • GordigGordig Posts: 10,720
    Do you mean that it falls completely through to the floor, or just that there’s poke-through?
  • PhatmartinoPhatmartino Posts: 287
    Any chance in your Simulation Settings, Frame Rate Multiplier is set to something (probably lower) other than 2? I've played around with some success with some garments for particular effects setting it to 1, but generally it would cause exactly what you're talking about...
