[Resolved] How to load a prop into active viewport instead of at origin?
DMaxDMax Posts: 637
edited June 2020 in New Users
I find this terribly annoying and it must only be because of my lack of knowledge. It must be possible to force load a prop (eg. person, table or ghost light) into the active viewport?
Right now my props all load at the "origin" and it's such a hassle having to locate it and then to bring it to where I wish it to be.
Post edited by DMax on
  • fixmypcmikefixmypcmike Posts: 19,735
    Can't remember the key to use offhand, but I think it's holding down Alt while dragging the item from your Content Library -- a target will appear in the viewport, release the item when it's at the right spot.
  • DMaxDMax Posts: 637
    Goodness! It worked!! Hold down OPT and drag the prop from the Content Library.... this is GREAT!!! Thank you so much kind sir, you helped remove a big grief I had!! <3
  • barbultbarbult Posts: 27,624
    Also take a look at mcjComeHere and the rest of his wonderful scripts for Daz Studio.
