Is it possible to keyframe an effect like this in DAZ?
vindazivindazi Posts: 671
How do I keyframe an effect like this using a character in DAZ?
https://www.youtube.com/watch?v=MkxYnzGWV4w
  • JaderailJaderail Posts: 0
    No. Textures are not Key Frame able in DAZ Studio. But there is a Texture Script Plugin that can be used to do it.
    http://www.daz3d.com/plugins-utilities/animated-textures-script-for-daz-studio
  • P_P_P_P_ Posts: 0
    Hello
    Maybe in this particular case, if you
    -set eyes color to ambiant 100%
    -set skin color, to white
    -change light color for changing the color face.
    It may works try on a simple sphere to check (I'm not sure but it may works).
    Regards
  • NoName99NoName99 Posts: 322
    edited May 2014
    You might be able to cheat something like this by loading multiple figures in the same exact location in your scene. Apply a different texture to each figure, and Keyframe the Opacity level to make a figure disappear and a new figure appear underneath.
    I haven't actually tried this so I have no idea if it will work. I suspect this would require key framing the scale % as well.
    Hopefully that script Jaderail posted above works to avoid any if this nonsense, lol.
    Post edited by NoName99 on
  • Richard HaseltineRichard Haseltine Posts: 111,348
    You could do it with Shader Mixer, the variable brick will give you the frame number or time which you could then use to drive a transition with a Mix brick. It would be easier to set up if you had a skin texture (or textures) you liked that use the DAZ Default Shader as you could then copy them in as a brick set up in Shader Mixer; otherwise you will have to build your own shader.
  • RuphussRuphuss Posts: 2,631
  • Francis TaylorFrancis Taylor Posts: 84
    Its totally possible. Just change the texture at whatever point in the timeline you want the change to take place. no complicated scripts or anything like that required.
    Nope. In DAZ Studio changing the Figure texture changes the texture for the full timeline. I've been animating in DS a pretty long time and tried that way back when. The Script I listed is the newest most up to date and DAZ 3D tested method of animating textures in DAZ Studio 4.5+. It was created just for the never versions.
    A User could mimic it by doing many scenes and editing those into one file but that was not the question as I read it. I read it as a change from one to another texture over time in a single file. That would require a animated texture.
