Saving Fitted Shoes
Hi. After fitting a shoe to a character, how do I save the shoe so it fits again when it's loaded? For instance, I fit a pair of G3 sandals to G2. I want to load the sandals again and have them fit. So far, I've had to save the character with the shoes as a scene subset, then load everything together.
  • Richard HaseltineRichard Haseltine Posts: 111,831
    A Wearables preset should work, or if you expect to use them a lot it may be worth using File>Save As>Support Assets>Figure/Prop Asset.
  • A Wearables preset should work, or if you expect to use them a lot it may be worth using File>Save As>Support Assets>Figure/Prop Asset.
  • Prop asset! Yes. I need to use them a lot. I think I tried saving as a wearable before, and it didn't work out for me. I'll try this.
  • dennisgray41dennisgray41 Posts: 962
    Thanks. This helps me too. I have a number of items that I need to save the surfaces settings on. Gets old having to go back everytime and paint a whole car in IRay.
