Constraints Do Not Work.
msolomonmsolomon Posts: 213
Hello everyone. I have a strange problem in 8.5. I just finished rigging a newly built character and tried to apply constraints to the bones. The constraints simply do not work. I tried the different types and they just do nothing. Has any one encountered this problem?
  • msolomonmsolomon Posts: 213
    edited May 2014
    I think I figured it out. I forgot I was trying to use an old rig from an old character with a much newer version of Carrara. I just made a simple rig in 8.5 and the constraints worked just fine. I thought an old Carrara rig would work in the the newer Carrara but it didn't. The meshes and textures still work but I will have to re-rig my old characters in 8.5. Not a show stopper but still a royal pain.
    Post edited by msolomon on
  • DiomedeDiomede Posts: 15,469
    I have been able to set constraints for bones successfully in C8.5, but I have only tried a small subset of all the possible constraint types.
    There are a number of constraint settings. I have only used limited for a ball axis. I have had success when I select the bone in the assembly room, go to the motion tab, then the constraint submenu, then I have chosen the "ball joint" for constraint type, then I have chosen "limited" for each axis, and then set the range of permissible movement with the dots on the circles.
    That works for me.
    651 x 401 - 200K
    edited May 2014
    sorry, misunderstood
    Post edited by wetcircuit on
    Glad you already got it worked out.
    edited May 2014
    I believe it was 7.2.
    That works for me.
    Thanks diomede64,
    I've been setting constraints for my custom character for a while but this is my 1st time trying to take a short cut and use an old rig. The constraints acted as if the rig wasn't there.
    I figured a work around. It seems models and riging from 7.2 do not respond to 8.5 constraints. I believe the problem rests in the file itself. So I created a new file, imported the old Carrara file into the new 8.5 document and the original constraints worked fine.
    Hours of tedium averted.:lol:
