Vintage Surgical Props
PlantPlant Posts: 127
Hi if anyone has got this could you see if the screen , light , table have any moovment morphs or just static cheers.
  • felisfelis Posts: 6,583
    I usually go by if it isn't mentioned in the description, then I don't expect it.
    But in this case, it was actually not the case. They are both rigged.
    The lamp head can rotate, and for the table, the head end can raise, and the foot end can lower.
  • PlantPlant Posts: 127
    Thanks Felis for taking the trouble,i was realy  hoping for the screen but can't have everything
    Ah, a scrrenshot is easy.
    You can see the bones in the scene tab.
    965 x 610 - 157K
    I was reffering to the medical screen in the set ,but thanks anyway thats great
    I misunderstood. But that is not rigged.
  • NylonGirlNylonGirl Posts: 2,414
    When I first saw that skull saw, I looked it up and found out that is a real tool. I can't imagine a situation in which it could be used to make a person's health better instead of worse.
