DAZ control menus moving around spontaneously?
Am I losing my mind, or do DAZ controls, such as Save, Create. Windows, etc., sometimes move around seemingly at will? Please tell me I'm not going 'round the bend.
  • SevrinSevrin Posts: 6,314
    I don't think it would be responsible to venture an opinion on your mental stability, but there's probably a good reason for things moving around.   They have been known to migrate with upgrades, and there's the Window>Workspace>Update and Merge Menus option that allows you to reset them.
  • fastbike1fastbike1 Posts: 4,084
    edited June 2020
    No they do not move around spontaneously. There are several ways for the user to move them, often without realizing.
    Post edited by fastbike1 on
  • RenderPretenderRenderPretender Posts: 1,041
    edited June 2020
    Well, they're different from yesterday. For instance, Open Recent used to be directly underneath Open. Now it's not. Other menus have also been changed. I had to re-select my preferred workspace. It's odd.
    Post edited by RenderPretender on
  • Richard HaseltineRichard Haseltine Posts: 111,503
    Try reloading your layout (Window>Workspace>Select layout), or at lleast the menus using the Load button in Window>Workspace>Customise. I would suspect this means that DS is not shutting down properly, either directly due to an error (most likely a third-party plug-in) or due to force-quitting as it shuts down. It coudl also be soemthing (security software or soem kind of system utility) blocking or corrupting the layout files that are written on close.
  • mindsongmindsong Posts: 1,788
    Yes they do.
    Not often, but to those who haven't seen it, the assertion that they do not is arguably presumptuous in a problem-solving context.
    Not sure why either - no trend identified (use DS a lot, so I'd likely notice some pattern).
    Restarts and the "menu-bar->windows->workspace->update and merge menus" sometime help.
    Per Richard's comment, DS generally saves it's menus/configs upon exiting, so if anything odd occurs during a DS shutdown, corruptions of the settings may occur - best I can figure.
    cheers, and no, it's not just you.
    --ms
    mindsong said:
    Yes they do.
    --ms
    Thank you! I'm relieved. I'll try your fix next time to see if that helps.
  • FirstBastionFirstBastion Posts: 8,076
    Different questions but similar,  Has anyone noticed that the cursor and viewport jump on occassion. A sudden 30-40 degree shift vertically while panning across the screen?
  • marblemarble Posts: 7,500
    mindsong said:
    Yes they do.
    --ms
    Seconded. I have tabs rearranging themselves, toolbar icons crowding together and losing the spaces between groups of tools. Normally a restart fixes the toolbar but I have to arrange the tabs myself.
    I've also noticed lately that smoothing stops working for clothing and I have to switch to interactive to get it to start again (normally I have interactive smoothing off).
    marble said:
    mindsong said:
    Yes they do.
    --ms
    That last tidbit is a gem - would never have thought to go that way.
    --ms
