AoA Rock Shader - Error when trying to load rock
Daniel Barnett
I get the following when I try to load any of the presets into the scene:
*** Scene Cleared ***
Error reading file, see log for more details.
That's all that appears when I try to load 1-Rock-A??
Any ideas why this happens?
Thank you!
dbb
Post edited by Daniel Barnett on
There is an online help manual here : http://ageofarmour.com/3d/tutorials/AoA_rock_shader_help.html
These are shaders, so I think you need to supply a surface for these to be applied to. Select the object in the Scene pane, select it's material in the Surfaces pane, then apply the shader, that is the normal way of doing it.
Thank you!
I did find I needed to have an object to apply the preset to. I'll get it right eventually!! I guess I'll need to learn how to create rocks!!
Thanks again for your reply!!!
dbb
