Can Tigerlily be used without Giselle 6?
So, can Tigerlily be used without Giselle 6?
Do you need it to be able to uses the texture map like so Gen4 for G2F? or is it just for shaping?
She uses the base G2F UV set, so her textures can be used without owning Giselle. The morphs need Giselle though, so you won't get the same look without owning her.
You can use the morph on G2F, too, it looks pretty good. Not quite like when using Giselle 6, but it strill works very well. :)
The girl in the middle is tiger liliy with Giselle 6 ("out of the box"), the one to the right is her using just G2F and the Tiger Lilly morph&skin;.
Thanks your the info.
