What is it???
OK! I have enjoyed the Install Manager up till now. But when I get a strange download in my ready to install section, that I don't recall, downloading or purchasing. It puts my spidey senses on alert. Anyone know what this strange file is, and is it safe? The said file is:
Postgre SQL CMS From Valentina CMS Conversion
It has a tag for the install manager. I cant find anything else on this file. And I don't recall the install manager getting updates in this manner.
Anyone know? Any help would be great.
Please and thank you!
http://www.daz3d.com/forums/discussion/41482/
check there,, and if you not hope to use new postgre database CMS,
or could not understand well at current,
just ignore and do not install postgre SQL, and the auto convert data script
which only need to install when you hope to use postgre CMS then import data from valentina (default CMS)
Then if you are carrara 8.5 user, and hope to smart content view,,
you may not hope to install postgre SQL at current.
And if you use Zone alarm to protect your PC, postgre database can not work as you expect.
about this case you keep to use valentina CMS, not install postgre.
Anyway I think,, read all and check seems better,,^^; after that try new postgre sql if you need.
