Auto fit of v4 costumes to G3F doesn't work well with daz 4.12.
Adapting certain morphs after autofitting the V4 outfit to G3F in daz 4.12 will break the v4 outfit. All morphs have auto-fitted properly until daz 4.9. This problem has always occurred since daz 4.10. Previously, I posted a similar problem with daz 4.11 and I got how to use the smoothing modifier, but The method using the smoothing modifier is heavy and very inconvenient. it's not a fundamental solution.(https://www.daz3d.com/forums/discussion/343696/auto-fit-of-v4-costumes-to-g3f-doesn-t-work-well-with-daz-4-11#latest)
Upon further investigation, it seems that the morphs that Auto fit does not work well with are Heavy, Voluptuous, Weight, and pear figure of Genesis 3 Female Body Morphs.  Also, the morphs of Heavy, Voluptuous, Weight, pear figure of Body Mixer for Genesis 3 and 8 Female are working.(https://www.daz3d.com/body-mixer-for-genesis-3-and-8-female) First I want to know if this problem is my personal one or a global one.
Is it an Autofit product (https://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s) problem or a G3 problem? These morphs are in heavy use and are looking for a radical solution.
1920 x 1040 - 300K
1920 x 1040 - 306K
    If it is just a bit of pokethru, then add a smoothing modifier to the outfit with collision (edit - figure - geometry - add smoothing modifier) and that usually fixes it.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    Have you reported this via a support ticket?
  • ittonnittonn Posts: 21
    The method of using the smoothing modifier was not realistic because the numerical value would be extreme.
    Should I consult the Help Center? Is this a potential product problem?
    It might be a DS or a product problem, so it's certainly worth a report - with steps to reproduce.
