GPU render?
I just bought a new laptop with a RTX 2080 and a i9 cpu. I have the latest Nvidia Studio driver installed.
On my old computer, when I rendered on the GPU only option, the CPU stayed pretty quiet and didn't get hot. With my new computer it says that it's rendering on the GPU only, but the fans are running at full blast and the cpu is running much hotter than the gpu. 86 C gpu vs 95 C cpu. My tech tool says the GPU load is 99-100%
Is this right? Should my cpu be working so hard on a gpu render?
Here's the log at the beginning of the render.
Rendering in NVIDIA Iray
Compiling Shaders - 0/1
Rendering image
Rendering...
Iray (Statistics) : Geometry memory consumption: 305.111 MiB (device 0), 0.000 B (host)
Iray (Statistics) : Texture memory consumption: 798.547 MiB for 241 bitmaps (device 0)
Iray (Statistics) : Lights memory consumption: 96.712 MiB (device 0)
Iray (Statistics) : Material measurement memory consumption: 0.000 B (GPU)
Iray (Statistics) : PTX code (286.153 KiB) for SM 7.5 generated in 0.202s
Iray (Statistics) : Materials memory consumption: 790.172 KiB (GPU)
Iray (Iteration) : 1
In render settings you can choose to not have the CPU enabled for Iray endering. A RTX 2080 should be able to render a scene without CPU. 99-100% GPU use is normal during renering. I always have both GPU and CPU enabled without problems.
