Tattoo Seam Question...
SaintSaint Posts: 126
edited June 2020 in New Users
I've noticed that some L.I.E. tattoos and body paint create seams with different Genesis 8 characters, this one is Calatea HD for example. Is there a particular fix for that issue? Thanks in advance!
Post edited by Chohole on
  • FenixPhoenixFenixPhoenix Posts: 3,237
    Is the tattoo only applying on the diffuse texture? Or is it applying on other maps? Also, check to see if the seam is there before applying the tattoo. I've come across certain light sets that create seams (not sure why).
  • SaintSaint Posts: 126
    The seam wasn't there before I applied the tattoo preset. Tried it with a few different characters from iSourceTextures including Aino and Calatea.
    To answer your other question, the tattoo applied only to the Base and Translucency. Works fine on base Genesis 8 and Skin Creator surfaces though.
