adjustig hight
edlaedla Posts: 16
how do you adjust the hight of a figure without scaling everything?
  • SevrinSevrin Posts: 6,314
    It depends on the morphs you have available.  The simplest is scaling only on the Y-axis.  If you have some basic morph sets, you can also try increasing things like thigh or shin length.
  • edlaedla Posts: 16
    the thing is all I get is a single scale parameter that scales everything at the same time
    If you get the base morphs, there is a height slider
    https://www.daz3d.com/genesis-8-female-body-morphs
    edited June 2020
    Yeah, forgot the y-scale is hidden for characters.  If you type "length" or  "height" into the search box when you select "Actor" in the parameters does anything come up?   If you want to start adjusting characters, you should get the morph set FSMC mentioned.  There is a similar one for faces, which you should also get.  They're on sale a lot.
    You won't get ALL these morphs with the basic morph pack.  I have a lot of other morph packs.
    467 x 601 - 75K
    Post edited by Sevrin on
    I have them I guess I'll just have to hunt them down. thank you
    thank you the pictures help.
  • What's wrong with the Scale parameter?
    It's quick and efficient. It does not fundamentally change the shape of the figure like some of the Length morphs, which can cause clothing distortions and other problems.
    Yeah, you have to address Scale with props that your character holds onto. The solution for that is math - simple division.
    Really, Scale is the first thing I use unless I absolutely want to change the shape of the figure and not just the height.
  • kyoto kidkyoto kid Posts: 42,464
    ..look under Actor/Full Body/Real World.
    scale is the last thing I would use since it affects more than just the height on a figure which can throw off the proportions.
    found the slider for height but it only goes down to 5'6" I'm trying to get to 5'3"
  • xyer0xyer0 Posts: 6,518
    edited June 2020
    Can you start with a shorter figure, like Mei Lin? Or even dialing some Mei Lin in should work.
    Post edited by xyer0 on
    Teen Jane & Alawa are alternatives to Mei Lin (their all 5' 4"). Rynne and Mika are 5' 3" or so. Karyssa's 5' 2".
  • JOdelJOdel Posts: 6,322
    After using the height slider then go and use the legs length slider. Or. like they say, start with a shorter figure to begin with.
  • scale is the last thing I would use since it affects more than just the height on a figure which can throw off the proportions.
    You dial in a character, you like the proportions, then you remember to check the height... and then when you use the Height dial to anything more than a slight adjustment, you get spider legs (making taller) or a barrel body (making shorter).
    Then you need to start the proportioning process all over again to achieve something that is pleasing to the eye.
    Maybe the Height dial produces something that is "realistic", but I don't put much stock in realism. Scale is faster, and less disruptive.
  • ChezjuanChezjuan Posts: 548
    Click the gear on the height slider, select parameter settings, and uncheck "use limits" next to min and max and you can go shorter. I have several characters smaller than 5'6" by turning off parameter limits.
    thank you that worked.
