Vicky Low Res?????
Edd_ weavo-1
was trying to sort out Jim Burton's Supermodel Lori and in the readme he stated I need blmilwom.obj file to extract the file with, but in the mover it says blmilwomLo.obj to extract with, so is there any way I still get this file from which package?
That's going really far back its the object for Victoria 2 Lo Res!
Isn't that part of the original V2 base installer?
No, V2 Lo Res is a separate product
http://digitaldreams.bbay.com/down.htm
Go back. The second DL is a file called supermodel_lori_revised.zip. It is based on blMilWom.obj.
If you read Jim's blub, Lori's mouth doesn't open. Some expression morphs don't work well on this morph.
Well may not what you might be looking for but there is a Vicky 3 Reduced Resolution here.. http://www.daz3d.com/victoria-3-reduced-resolution
OK thanks for that info, re-downloaded, will try again and see what happens 2morrow.
