Turn off duplicate formula error message
cheznous2029_28ab1adedc
There should be a way to turn off the duplicate formula error message when loading a scene!
Turning off the message wouldn't affect load speed, and would remove useful information (if there are duplicate formulae, whether it's a clash between two products using the same name or a bug in a single product, something is not working as it was intended to).
I found the fix for this problem hereÑ
https://www.daz3d.com/forums/discussion/22220/duplicate-formulas-error-solved-thank-you-bejaymac/p1
That's almost certainly a different problem, unless you're using the original Genesis figure. There's a duplicate formulas error that's specific to original Genesis -- you'll note that the original date for the thread you linked was from 2013 -- and another one that occurs with Genesis 2, 3, and 8.
Did that fix actually work for your issue?
This did work for three of the four files that I was having problems with but not all of them.
