fbx import
my working drawings of joinery furniture stairs etc are drawn in autocad 2012 and dxf files sent to the cnc router when I export these
drawings as fbx files so that I can import into daz studio and add figures it seem to import them but they are not visable can anyone help
Do they appear in the Scene pane?
It may be that they are transparent, and you would need to select the item in the Scene pane, then go to the Surfaces pane and check the Opacity tab.
The other problem may be the Scale, if it is too small, they may not be visible. Use the View Frame key with the object selected in the Scene pane, it looks like a hollow square with a plus sign in the middle at the top of the viewport.
