camouflage clothes for daz studio models?
Hi everyone I'm after some camouflage clothes for genesis or michael, I've found some trousers but is there any tops (jumpers) available anywhere as I need them for my animation.
Machpack http://www.daz3d.com/machpack includes multiple camoflage shaders which you can apply to any clothing, with a wide choice of displacement textures. This will allow you to design your own camo outfit using items from different sets if desired.
Fisty's http://www.daz3d.com/hardcore-utility-shaders-ds
Chears for that I'll use them are they used for genesis or Michael?
Shaders are generally used on the surfaces of clothing, and they are not specific to any particular model or generation.
Just make sure that the object you want to apply the shader to, is selected in the Scene pane AND the Surfaces Pane, then double click to apply it.
Has anybody used these? Do they work on Daz Studio?
http://www.renderosity.com/mod/bcs/camouflage-textures-set-1/38055
Those would work, they are just Tileable jpg files that would be added to the surfaces and the number of tiles set.
It looks as if you would need to understand how to use then by hand. No load icons and such I do not think.
Ok then so not the best option then I'm using the machpack at the minute but can't get them to load I read up on the shader and it says to go into surfaces but cannot find the correct option to click on to use them how do you get them to load up I've selected my model and clothing but still not loading up.
Shaders once Applied only Show properly in a Full render.... or Spot Render. But that one should show in the Viewport..
Chears I'll follow this, helps alot.
Done everything the picture have shown me I've selected a texture to test out and this message is appearing, I used the daz install manager to install the product.
That tells me that maybe your content folders are not mapped properly. Here is a default mapping of the Default paths... If your DIM uses a different Path I will need to know to fix that.
This is mine.
Here is what you should have for Proper use of all your DAZ 3D content...
Oh right, ok then I'll sort that out now, chears for the help much appriciated :)
