how to get the Iray preview box pls
DrekkanDrekkan Posts: 460
On the right top corner of the screen I have it turned off but how do you turn on the Iray render preview box (or whatever its called) please.
  • In your viewport, there should be icons in the upper right. These allow you to customize the View.
    The round thingy to the left of the View selector box? (Mine is set to Texture Shaded.)
    Nvidia Iray view is under there.
  • DrekkanDrekkan Posts: 460
    Nvidia Iray view is under there.I meant the Iray RENDER preview box on the top rightcorner (not in viewport area)
     Thx but you misunderstood I meant the small Iray RENDER preview box on the top right box (not in viewport area)
  • TaozTaoz Posts: 10,320
    If you hover over it with the mouse you should see the same controls as in the Viewport, just use these instead.
  • Lyrra MadrilLyrra Madril Posts: 284
    you want to turn on the Aux Viewport .. in the top menu under Window then Tabs
    LM
  • FSMCDesignsFSMCDesigns Posts: 12,855
    LM
    interesting, never knew that existed.
