Hair help
hello I do not understand one thing, how come when I go to put the hair to the character so I appear after
1920 x 1020 - 477K
  • Richard HaseltineRichard Haseltine Posts: 111,996
    That's the Genesis or Genesis 2 version of the hair - one clue is that the icon next to the hair in the scene pane has only dotted lines separating the cubes, unlike the Victoria 4 icon which has solid separators. Do you have the Victoria 4 version of the hair - it would usually be in Poser Formats>Your Library>Figures>AprilYSH
  • edited December 1969
    I do not understand forgive me
  • fixmypcmikefixmypcmike Posts: 19,741
    The hair you are using is made for Genesis or Genesis 2, but you are using it on Victoria 4, a different figure, so the default location it loads in is not correct for that figure. If that hair does not also come with a Victoria 4 version, you would need to use the scale, translation and rotation parameters to position it.
    Did you purchase Portia Hair or Portia Hair 2? The original Portia Hair is for Victoria 4; Portia Hair 2 is for Genesis and Genesis 2.
