problem with installing content with DIM...
Ok so I combined several libraries together when I moved them from one drive to another. Some of my content stopped working. So I deleted them with DIM and tried to reinstall them, but some of them didn't install again, so now I have quite a bit of stuff that won't install again. Two of the files are ones that say7 that they need to be installed to use Daz Studio. But even after moving my downloaded files, and downloading the indicated required files, I get an error.
This file cannot be opened for reading This package cannot be installed.
Anyone know what is going on?
    Check what the permissions are on a zip that isn't working, and see if you can unzip it manually.
  • Sensual ArtSensual Art Posts: 646
    edited June 2020
    DIM has its own log files (separate from DS) under %APPDATA%\DAZ 3D\InstallManager\log.txt
    You may have get better insights from there.
    Post edited by Sensual Art on
  • MalandarMalandar Posts: 777
    Okay, I am stupid...
    I forgot to check the amount of space I had on that drive... I was low on space so things like pose sets and morph sets were loading no problem because they are small, but anything with a texture set was failing (which was most of the stuff I was reinstalling in the first place) So yeah...
    Thanks for the suggestions on what to look for though, I appreciate the time you took to try to help me out.
