How to fix hand rigging for female sasquatch morphs for G8M
Hi there, I don't know if this is the right place to post this question, but It is a technical issue I'm having.
Recently I bought the sasquatch figure by Raw Art and I've noticed a problem.
When I apply the female morphs that come with the sasquatch model. I get an issue when I try and move the character's fingers.
I don't have this problem when the male morphs are applied, it only happens when the female morphs are on.
Other than the hand issue the rest of the model works fine with no other issues.
What is this problem I'm having? is it a rigging issue? and how can I fix it?
Post edited by FlippedDimensionComics on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Your image won't open for me, the site triggers a security warning.
    Are you sure you are using the right slider? From your description it sounds as if you may be using the (usually hidden) Genesis 8 Female clone shape that allows AutoFit to work, but which isn't made to be used as a morph.
    RawArt has made a few Sasquatches, etc.
    Is this the product you are talking about? https://www.daz3d.com/dforce-sasquatch-for-genesis-8-male
    And is that problem happening when you apply the female shaping preset?
    If the answer is yes, then file a CS ticket so RawArt can fix it ;-)
