Can't see 200 face morph sliders
Hi,
I've installed 200 face morph sliders for DAZ (copied to the correct folders in My DAZ3D Library, double-checked - everything is where it should be)... However, I don't seem to have them appear in the parameters section when I select the head. Am I doing something wrong? I've been following the YouTube tutorial below and it seems that where he's supposed to get those sliders - I don't.
https://www.youtube.com/watch?v=wtxsDxKY5Ok&t=235s
All my files seem to be where they should, e.g. C:\Users\Public\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 8\Female\Morphs\DogZ&Zev0\200 Plus
  • barbultbarbult Posts: 27,475
    edited June 2020
    Have you tried closing Daz Studio and restarting it? If you install new morphs while Daz Studio is open and your character is already loaded, you won't see the morphs immediately, because Daz Studio decides what morph sliders are available for the character when the character is loaded.
    Post edited by barbult on
    Also, be sure you are selecting Genesis 8 Female in the Scene pane, not her head. In the Parameters pane you can select the Head or one of the subelements, like Face and you should see the 200 Plus morphs. Take a look at my screenshots.
    551 x 1619 - 123K
    555 x 1816 - 174K
  • SixDsSixDs Posts: 2,384
    This can be confusing for users with older as well as newer content. Pre-Genesis figures normally required the head to be selected in order to access morphs for the head, but the more recent Genesis series of figures display all the morphs, including those for the head, with the root node of the figure selected. If you wish to see only the sliders that affect the head, you must drill down in the heirarchy under the Parameters tab and select Head under Actors.
