No lips
My GM8 has white lips when I render. I can not find "lips" to attach. Also looked in the store. Any suggestions??
Thanks
  • MimicMollyMimicMolly Posts: 2,378
    edited June 2020
    Are you rendering in Iray? If you are, go to the *Surfaces section, go to Lips and turn off "Diffuse Overlay". Sometimes that setting makes faces white during render.
    *Oops, "Surfaces", not "Materials". Too early.
    Post edited by MimicMolly on
  • FenixPhoenixFenixPhoenix Posts: 3,249
    edited June 2020
    Indeed, the culprit is most probably that the Diffuse Overlay got activated.
    • With your character selected go to your surfaces (windows > panes > surfaces).
    • Then locate the lips surface.
    • There you will find a channel called Diffuse Overlay Weight. You want to dial that one down to 0.
    That should take care of the issue.
    If this is happening to your genesis 3 or 8 character, this material preset will work (I made it for a product that's coming soon). Just save it anywhere in your library and apply it to the character with white lips.
    duf
    duf
    Overlay White Lips Fix.duf
    847B
    91 x 91 - 13K
    Post edited by FenixPhoenix on
