Can I pose 2 or more Body parts at the same time in DS?
nakamuram002nakamuram002 Posts: 823
There used to be a way to pose two or more body parts at the same time in DAZ Studio. I could do things like select all finger parts in the Scene Window and bend them the same amount by setting Bend in the Parameters Window. This useful feature seems to have vanished or hopefully can be done in another manner, in the latest versions. If the latter, how can I do this?
    edited May 2014
    You can still rotate or move selected parts at same time.(change properties value at same time)
    it is setting of each tab. (parameter tab, and posing tab about your case)
    click option menu icon of tab, or R-click on the tab Label
    If you want to use parameter tab, to rotate selected rigs as the same time,
    1. check "on" consolidate properties.
    ds gather all selected properties,, and you can change value at same time.
    if it can not work for your purpose , you need one more setting.
    2 check off " Display separate items."
    when you check on Display separate items,
    it show you all nodes, selected, in the tab left pane.
    it is useful,, but you need to select each node with ctrl key, in parameter tab again.
    to change value at same time.
    even though you select mutli nodes in scene tab, it can not be reflected in the parameter tab
    as selected.
    it is almost same about another tab setting.
    you may find clear check on off by your self then see how it work with scene tab selections.
    Post edited by kitakoredaz on
