How do I: DS Timeline?
In Keymate/Graphmate, there is an option to select which properties (or key types) to show keys set for: TR, TRS, or TRSV.  For the DS Timeline, I can select TRS properties (I have property types set to TRSAH), but I have not figured out how to show a key set for the nodes that have "value" properties set at a particular frame.  For example, if I go to frame 15, and change a morph value on a hair, I can see that a key set in the graph pane but I do not see a key set in the timeline view.  This is very important as I may have values set somewhere along the timeline and not even know where they are set because a key does not show in the timeline.  How to fix?
Thank you.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    O (for other) is the equivalent. V (for value) did not reflect all the things that were in that set.
  • artistb3artistb3 Posts: 188
    edited June 2020
    I saw O (for other) but it does not appear to be selectable? Never mind.  It is selectable and that was the issue.  Thanks.
    Post edited by artistb3 on
