Buildings and rooms
kaotkblisskaotkbliss Posts: 2,918
Hello, I'm back with another question.
Is there a way to remove just the roof/ceilings from rooms and/buildings such as Daz's Level 19 or the Asylum so that you can set the camera above the building and look down in?
  • macleanmaclean Posts: 2,438
    edited May 2014
    It depends on the model and how it was made. If it's a figure, expand the body parts in the Scene pane and look for a 'ceiling' part or whatever. If it's there, you can switch it off.
    If the model doesn't have separate body parts, or if it's a prop, try looking at the materials in the surface pane. If there's a 'ceiling' material, set Opacity to zero to make it invisible.
    At the very worst, if there's absolutely no way to hide walls or ceiling, use a wide angle on the camera, like 25mm. That gives a wider view without moving too far back, so you can place the camera inside the room. (You may have to create a new camera to do this).
    mac
    Post edited by maclean on
  • kaotkblisskaotkbliss Posts: 2,918
    Thank you much!
  • Richard HaseltineRichard Haseltine Posts: 111,647
    You can also select the polygons in the part you want to hide and assign them to a new material, if they aren't already in a material of their own - the Grouping Tool in Poser or the Geometry Edit tool in DAZ Studio.
