x
jjohnyjjohny Posts: 0
edited January 2016 in Daz Studio Discussion
x
Post edited by jjohny on
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,249
    Is the skin a SSS shader? Have you changed the scale of the figure?
  • jjohnyjjohny Posts: 0
    I resize it but when i use an other actor and I resize it, there is not this problem. You know why?
    I have a feeling its an issue with scaling your figure and the SS Shader skin.
    Try lowering the Shading Rate on the skin surfaces and see if that helps.
    And how do I do that? I am a begginer so I don't know ^^'
    Its a surface setting. Select your figure then bring up the surfaces tab. Then you need to select all of the skin sufaces on the figure in the surfaces tab.
    If you scroll down one of the settings should say Shading Rate.Try reducing this number setting. Soryy im not at my computer right now or i would give you some screenshots.
    Thanks for the help but it doesn't change anything :/ Any other idea?
    edited May 2014
    Ok thanks for helping me I've founded the problem (it was a scaling problem). Now it's better!
    Image removed by Moderator
    Explanation, the alteration in the pose now shows the pubic area of the character below the skirt
    Post edited by Chohole on
    Good news! Glad you got it sorted!
  • XoechZXoechZ Posts: 1,102
    There is some kind of a "rule" in 3D. Well, not officialy, but it is a rule for me.
    If you have 2 items of different scales and you want to match their sizes, always make the bigger one smaller (downscaling) instead of making the smaller one bigger (upscaling). With upscaling you always loose quality.
