how to make a smart prop ?
va-silyva-sily Posts: 52
I want to make a smart prop to Victoria4.2. how to attach a prop on the head of Victoria or on the shoulder or on foot? show step-by-step workflow please.
  • va-silyva-sily Posts: 52
    I want to make a smart prop to Victoria 4.2. how to attach a prop on the head of Victoria or on the shoulder or on foot? show step-by-step workflow please.
  • Cayman StudiosCayman Studios Posts: 1,141
    You set the prop up, parented to Victoria in the way you want, then save it either as a Wearable preset, or as a Prop Asset.
  • JaderailJaderail Posts: 0
    edited May 2014
    That does not work for None Triax figures. V4 is not Triax, V4 is poser format. Proper smart Propping of items to the Generation 4 figures is done by editing the Prop's load script after a New Script is generated with the Item placeed and saved from the proper T pose load location. The X,Y,Z coordinates need to be in the Load script before the Smart Parenting is set On with the proper code.
    The Above method will work if the User converts the V4 to a Triax Weight mapped figure, but it will only work in DAZ Studio with a Triax version of V4 loaded. The Proper script method will work in both DAZ Studio and Poser.
    Post edited by Jaderail on
    Thank you very much for your answers, I will try.
