Odd issue with Iray Rendering not using GPU
Hello, I've recently have an odd issue where the GPU isn't being used to render at all.
Seems i'm getting errors with GPU but have no idea why it's giving the errors.. it worked just fine in the past, and it works for everything else.
Going to try a clean re-install of the driver and see if that fixes it, any ideas would be great beyond that
2020-06-05 23:37:38.332 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.000s
2020-06-05 23:37:38.332 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
2020-06-05 23:37:38.340 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
2020-06-05 23:37:38.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
2020-06-05 23:37:38.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2020-06-05 23:37:38.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2020-06-05 23:37:38.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
2020-06-05 23:37:38.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2020-06-05 23:37:38.342 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:38.344 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2020-06-05 23:37:38.346 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
2020-06-05 23:37:38.346 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
2020-06-05 23:37:38.346 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (GeForce RTX 2070 SUPER): invalid program counter (while allocating host mapped memory buffer)
2020-06-05 23:37:38.347 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (GeForce RTX 2070 SUPER): device cannot be used as it does not support mapped memory (canMapHostMemory)
2020-06-05 23:37:38.347 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : All available GPUs failed.
2020-06-05 23:37:38.347 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : No devices activated. Enabling CPU fallback.
2020-06-05 23:37:38.347 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (GeForce RTX 2070 SUPER): Device initialization failed, will not be used
2020-06-05 23:37:38.347 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
2020-06-05 23:37:38.347 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2020-06-05 23:37:38.347 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
2020-06-05 23:37:38.347 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 24 cores for rendering
2020-06-05 23:37:38.347 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
2020-06-05 23:37:38.347 Iray [VERBOSE] - IRAY:RENDER ::   1.65  IRAY   rend progr: CPU: Processing scene...
2020-06-05 23:37:38.347 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : Initializing Embree
2020-06-05 23:37:40.464 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : Importing lights for motion time 0
2020-06-05 23:37:40.464 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : Initializing light hierarchy.
2020-06-05 23:37:40.465 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : Light hierarchy initialization took 0.001s
2020-06-05 23:37:40.499 Iray [VERBOSE] - IRAY:RENDER ::   1.42  IRAY   rend stat : Native CPU code generated in 0.031s
2020-06-05 23:37:40.557 Iray [INFO] - IRAY:RENDER ::   1.65  IRAY   rend info : CPU: Scene processed in 2.210s
2020-06-05 23:37:40.559 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : CPU: Allocated 7.73644 MiB for frame buffer
2020-06-05 23:37:40.641 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - POST:RENDER ::   1.0   POST   rend warn : renderer iray has no more devices available. Postprocessing falling back to CPU.
2020-06-05 23:37:40.646 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iterations after 2.293s.
2020-06-05 23:37:40.648 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:40.649 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2020-06-05 23:37:40.801 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 2.444s.
2020-06-05 23:37:40.802 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:40.949 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 2.593s.
2020-06-05 23:37:40.950 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.128 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 2.772s.
2020-06-05 23:37:41.129 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.271 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00009 iterations after 2.915s.
2020-06-05 23:37:41.272 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.405 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00011 iterations after 3.049s.
2020-06-05 23:37:41.406 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.548 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00013 iterations after 3.192s.
2020-06-05 23:37:41.549 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.705 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00015 iterations after 3.349s.
2020-06-05 23:37:41.706 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.851 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00017 iterations after 3.495s.
2020-06-05 23:37:41.853 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:41.997 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00019 iterations after 3.641s.
2020-06-05 23:37:41.998 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.154 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00021 iterations after 3.798s.
2020-06-05 23:37:42.155 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.311 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00023 iterations after 3.955s.
2020-06-05 23:37:42.312 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.447 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00025 iterations after 4.090s.
2020-06-05 23:37:42.448 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.614 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00027 iterations after 4.258s.
2020-06-05 23:37:42.619 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.772 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00029 iterations after 4.416s.
2020-06-05 23:37:42.773 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:42.930 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00031 iterations after 4.574s.
2020-06-05 23:37:42.931 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:43.076 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00033 iterations after 4.720s.
2020-06-05 23:37:43.077 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
2020-06-05 23:37:43.220 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
2020-06-05 23:37:43.220 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: 33 iterations, 2.217s init, 2.521s render
  • fastbike1fastbike1 Posts: 4,079
    @Xenos666
    Unless you give some info on your Studio version, your specific GPU and the NVidia dirver version, folks can't be much help.
  • Neuron EdGeNeuron EdGe Posts: 21
    edited June 2020
    fastbike1 said:
    @Xenos666
    Fastbike1 is correct, but I have the same/similar issue and have an open ticket with Tech Support, as described below.
    Bottom line: I upgraded Daz per Install Manager, lost ability to iRay render.  Again.  Same thing happened to many of us last year.
    Upgrading to 4.12.1.117 cancelled my ability to render (again). Can you please send me an installer for the previous build?
    This is the second upgrade where this has happened; last time it was fixed 8 months later with an eventual MSI video driver update. This time, I have the latest drivers and don't feel like waiting another 8 months.
    Specs:
    MSI GT62VR 6RE Dominator Pro Laptop
    Windows 64 bit
    48GB Ram
    NVidia GTX1070 8gb Graphics
    Graphics Driver: 22.21.13.8205, 5/1/2017
    2020-06-06 11:47:01.673 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2020-06-06 11:47:01.673 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices.
    2020-06-06 11:47:01.679 Iray Render error: Invalid parameters (NULL pointer).
    I'd be happy to go back to the prior version, if I cant get it.
    As for my OTHER 64gb, Win10, DUAL 980Ti,  32core, Daz 4.10.0.123 backup renderbox - it is NEVER getting upgraded, just for this reason.
    Post edited by Neuron EdGe on
    edited June 2020
    @Xeno666
    I read your log, and it seems your Driver may be newer than your Daz.
    You are getting "The 'iray_optix_prime' scene option is no longer supported." errors, and the latest Daz has removed that option (iray_optix_prime) from the UI.
    So, uncheck that option and give it a whirl.
    If that still fails, try plan B: upgrade Daz.  WARNING: If possible, SAVE your current installation of Daz (copy the daz folder?) or it's installer before upgrading, then try upgrading to Daz 4.12.1.117, which Install Manager should let you do.  For me it was in the Upgrades list. (Boy do I regret tapping THAT.)  Again, this is because the latest Daz has removed that option (iray_optix_prime) from the UI.
    Good luck!
  • Xenos666Xenos666 Posts: 2
    I figured it out, thankfully it was just an odd issue with my GPU overclock, seems it was stable for everything but Daz.. lowered it a bit, everything working now.
  • kenshaw011267kenshaw011267 Posts: 3,805
    fastbike1 said:
    @Xenos666
    Specs:
    Windows 64 bit
    48GB Ram
    MSI does not make drivers. Your problem is almost certainly that you are not getting the correct up to date driver from Nvidia.
  • Dark-ElfDark-Elf Posts: 956
    I have tried it on 4.12.1.117 and it's not recognising my GPU either. I installed the most recent drivers, release on 27th May 2020 and it STILL won't work.
    This is the last of my log file, when trying to render with iray:
    2020-06-06 20:29:24.676 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-06-06 20:29:24.688 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :  CUDA device 0 (GeForce GTX 980 Ti)
    2020-06-06 20:29:24.688 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-06-06 20:29:24.688 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend progr: CUDA device 0 (GeForce GTX 980 Ti): Processing scene...
    2020-06-06 20:29:25.013 Iray [VERBOSE] - IRAY:RENDER ::   1.11  IRAY   rend stat : Geometry memory consumption: 971.858 MiB (device 0), 0.000 B (host)
    2020-06-06 20:29:25.028 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Using OptiX Prime version 5.0.1
    2020-06-06 20:29:25.040 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Initializing OptiX Prime for CUDA device 0
    2020-06-06 20:29:25.627 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.11  IRAY   rend error: OptiX Prime error (Device rtpModelUpdate BL): Memory allocation failed (Function "_rtpModelUpdate" caught exception: Encountered a CUDA error: cudaMalloc(&ptr, size) returned (2): out of memory)
    2020-06-06 20:29:25.628 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 980 Ti): Scene setup failed
    2020-06-06 20:29:25.640 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 980 Ti): Device failed while rendering
    2020-06-06 20:29:25.640 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.6   IRAY   rend warn : All available GPUs failed.
    2020-06-06 20:29:25.641 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.6   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2020-06-06 20:29:25.652 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: All workers failed: aborting render
    2020-06-06 20:29:25.653 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-06-06 20:29:25.653 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-06-06 20:29:25.654 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-06-06 20:29:25.665 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend progr: CPU: Processing scene...
    2020-06-06 20:29:25.666 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Using Embree 3.6.1
    2020-06-06 20:29:25.666 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Initializing Embree
    2020-06-06 20:30:12.186 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Importing lights for motion time 0
    2020-06-06 20:30:12.333 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Initializing light hierarchy.
    2020-06-06 20:31:03.549 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : Light hierarchy initialization took 51.069s
    2020-06-06 20:31:04.999 Iray [VERBOSE] - IRAY:RENDER ::   1.11  IRAY   rend stat : Native CPU code generated in 1.422s
    2020-06-06 20:31:05.349 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : CPU: Scene processed in 99.677s
    2020-06-06 20:31:05.397 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : CPU: Allocated 29.755 MiB for frame buffer
    2020-06-06 20:31:08.959 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend info : Allocating 1-layer frame buffer
    2020-06-06 20:31:09.137 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - POST:RENDER ::   1.0   POST   rend warn : renderer iray has no more devices available. Postprocessing falling back to CPU.
    2020-06-06 20:31:09.302 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 104.600s.
    2020-06-06 20:31:09.480 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Available GPU memory has increased since out-of-memory failure. Re-enable CUDA device 0.
    2020-06-06 20:31:12.517 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-06-06 20:31:12.517 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :  CUDA device 0 (GeForce GTX 980 Ti)
    2020-06-06 20:31:12.517 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-06-06 20:31:12.524 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 107.765s.
    2020-06-06 20:31:12.524 Iray [INFO] - IRAY:RENDER ::   1.6   IRAY   rend progr: CUDA device 0 (GeForce GTX 980 Ti): Processing scene...
    2020-06-06 20:31:12.547 Iray [INFO] - IRAY:RENDER ::   1.11  IRAY   rend info : retrieving cached geometry for device 0, time 0
    2020-06-06 20:31:13.334 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.11  IRAY   rend error: OptiX Prime error (Device rtpModelUpdate BL): Memory allocation failed (Function "_rtpModelUpdate" caught exception: Encountered a CUDA error: launchAPMInit() returned (2): out of memory)
    2020-06-06 20:31:13.336 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 980 Ti): Scene setup failed
    2020-06-06 20:31:13.387 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 980 Ti): Device failed while rendering
    2020-06-06 20:31:13.388 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.6   IRAY   rend warn : All available GPUs failed.
    2020-06-06 20:31:13.411 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.6   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2020-06-06 20:31:13.426 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.6   IRAY   rend error: All workers failed: aborting render
    2020-06-06 20:31:13.436 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-06-06 20:31:13.436 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    There's no option any longer to untick OptiX Prime in DS so not sure how to fix this. I installed the update via DIM and it was working properly recently but now it's not and I don't know what to do.
    My setup is a custom built PC
    AMD Ryzen 5 1600 6-Core 3.69GHz processor
    GeForce GTX 980 Ti
    Graphic driver: 26.21.14.4614
    Driver Date: 15/05/2020
    16Gb DDR memory
    ​64-bit Windows10 Home
    The log says the scene exceeds the GPU VRAM.
    If you can't render a very basic scene, a single prinmitive with a texture then let us know.
    edited June 2020
    VERY Good Point!!  -- I must have reinstalled the original 2017 driver.  (Also explains why my HDR output to the 4K went caput;  thought that one was the Microsoft Update's fault.)
    Let me try the latest NVidia.  I'll post an update after.  Thanks!
    Update:
    HORRAY!
    That worked like a charm!  -- Thanks, @KenShaw011267
    so, this was from a different scene....
    2020-06-07 08:48:46.976 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-06-07 08:48:46.994 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2020-06-07 08:48:46.994 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2020-06-07 08:48:47.001 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-06-07 08:48:47.013 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :  CUDA device 0 (GeForce GTX 980 Ti)
    2020-06-07 08:48:47.013 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-06-07 08:48:47.014 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (GeForce GTX 980 Ti): Processing scene...
    2020-06-07 08:48:47.247 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Geometry memory consumption: 652.255 MiB (device 0), 0.000 B (host)
    2020-06-07 08:48:47.247 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing OptiX Prime for CUDA device 0
    2020-06-07 08:49:02.865 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Texture memory consumption: 789.553 MiB for 54 bitmaps (device 0)
    2020-06-07 08:49:02.866 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2020-06-07 08:49:02.866 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2020-06-07 08:49:02.866 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.000s
    2020-06-07 08:49:02.866 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Lights memory consumption: 196.000 B (device 0)
    2020-06-07 08:49:02.892 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Material measurement memory consumption: 0.000 B (GPU)
    2020-06-07 08:49:03.480 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : PTX code (157.411 KiB) for SM 5.2 generated in 0.587s
    2020-06-07 08:49:03.480 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Materials memory consumption: 283.059 KiB (GPU)
    2020-06-07 08:49:04.580 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : JIT-linking wavefront kernel in 0.878s
    2020-06-07 08:49:05.388 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : JIT-linking mega kernel in 0.796s
    2020-06-07 08:49:05.388 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 980 Ti): Scene processed in 18.375s
    2020-06-07 08:49:05.467 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 980 Ti): Allocated 29.755 MiB for frame buffer
    2020-06-07 08:49:05.565 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 980 Ti): Allocated 864.000 MiB of work space (1024k active samples in 0.066s)
    2020-06-07 08:49:05.577 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 980 Ti): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2020-06-07 08:49:05.914 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Allocating 1-layer frame buffer
    2020-06-07 08:49:05.976 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 18.962s.
    I'm guessing it's just my poor 980 Ti showing its age...??? indecision Roll on the 3000 series release smiley
    No. The first scene was larger than 6Gb and the second wasn't. iRay can only use a GPU if the scene fits in the cards VRAM.
    Except the first scene was not larger than 6gb.....
  • TheKDTheKD Posts: 2,711
    That line there in the first one, means it ran out of memory. It did it right after geometry, which is when it loads in the textures. If you saved the first scene, you could try it after a fresh open of DS, if it drops again, you will need to do something about making the textures take up less memory. Personally I use the scene optimizer product when I need to do that, makes it quicker and easier than manually resizing and relinking textures in the scene.
    @Dark-Elf "Except the first scene was not larger than 6gb...."
    You can't tell how large the scene is in Iray from looking at the size on the HD or in CPU ram. Use GPU-z to tell you how much Vram is used.
    hey which clock speed is good for daz. My daz is freezing cant render anything even my old scene which used to render properly
