Scale dial is missing ... Now what?
WillowRavenWillowRaven Posts: 3,787
I bought a WWII gun prop set from rendo, and the weapon I need has no scale dial at all, but it's a touch small for the character. Now what?
  • XoechZXoechZ Posts: 1,102
    If there is really no other solution, then you can always make the character a bit smaller, so that the sizes match. Depends of course on your whole scene, if this is useful.
  • fixmypcmikefixmypcmike Posts: 19,741
    In the Parameters tab make sure "Show Hidden Dials" is on.
  • fictionalbookshelffictionalbookshelf Posts: 837
    edited May 2014
    In Daz create a "New null" under the create menu. You can give it a name if you want or just leave it as 'null'. Once it's created it's invisible. Now select your prop item and parent it to the Null. Once parented you can select the null and use scale, rotate, and etc and it will change the prop to your needs.
    When you get everything the size you need, you can parent the null to your figure if you need to and the prop will 'follow' the figure's poses.
    Post edited by fictionalbookshelf on
  • WillowRavenWillowRaven Posts: 3,787
    Ahah! Found the hidden parameters. Thanks.
    Scale has been accomplished :D
    Oooo ... good info. That will also come in handy :D
