Z Natural Breasts - Shape and Pose Mega Set poses not working
I'm trying to use the poses from this set and I am finding that the do what they're supposed but the upper body will not work at all. It doesn't matter which pose I select. It will rotate and orient the body as expected too.
The breast shape apply / remove work as well.
I looked for documentation on the product but can't seem to find any.
Turning the limits off also does not help.
What am I doing wrong?
This is all that appears in the log file when attempting to apply one of the poses:
2020-06-04 06:45:56.709 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2020-06-04 06:46:06.685 File loaded in 0 min 0.0 sec.
2020-06-04 06:46:06.688 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.688 Loaded file: pJCM_Sahira8_ShinBend_90_L.dsf
2020-06-04 06:46:06.692 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.692 Loaded file: pJCMFlexHamstring_L.dsf
2020-06-04 06:46:06.696 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.696 Loaded file: pJCMShinBend_90_L.dsf
2020-06-04 06:46:06.702 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.702 Loaded file: pJCMBigToeDown_45_R.dsf
2020-06-04 06:46:06.705 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.705 Loaded file: pJCM_Sahira8_ShinBend_90_R.dsf
2020-06-04 06:46:06.708 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.708 Loaded file: pJCMFlexHamstring_R.dsf
2020-06-04 06:46:06.712 Loaded Morph Deltas in 0 min 0.0 sec.
2020-06-04 06:46:06.712 Loaded file: pJCMShinBend_90_R.dsf
2020-06-04 06:46:06.715 Loaded file: z nbs btm 05 g8f.duf
2020-06-04 06:48:14.811 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2020-06-04 06:50:56.116 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
1097 x 917 - 186K
  • Richard HaseltineRichard Haseltine Posts: 111,721
    https://www.daz3d.com/forums/discussion/comment/5624021/#Comment_5624021
    Another thread reports that the psoes are not applying the shapes, though the shapes themselves do work.
  • In my case the poses themselves are not working. If you look closely at the image I've highlighted the pose that I selected. You can see that everything from the waist up is still in the default genesis 8 female pose. However, the highlighted pose shows the body and arms in a specific pose not the defaults.
    I've tried other full body poses from different sets and they all pose the character properly, so this is exclusive to this set.
    It's almost as if there's a bone in the hip/pelvis area that isn't being accounted for so it just stops there... ?
    Well, the name does incvluce Btm - I suspect it's a partial pose for the lower body, there are probably others named soemthing like Upr. Zeddicus does do a lot of pose sets which have partial poses for mixing and matching.
  • I totally missed that
    Sorry to waste your time
    Heh, well I missed it too.
