Can't load any g8....
Will not load any g8 figure  g3 and g2 are fine
I started  a  ticket, but they haven't answered me in two weeks, must be busy
all content is kept on a WD 4tb hard drive,wgich is less than half full.
log is attempt at loading basic g8
thanks in avance
txt
txt
log 6320.txt
3M
    What do you mean by "Will not load any g8 figure"?
    Does DS crash or do you get tired of waiting?
    You have a ton of warnings in your Log-file related to Auto Face Enhancer, which can make loading any G8 character take, if not hours, several tens of minutes at least.
    I have had just one error cause 6 minute delay in loading a character
  • raceresqraceresq Posts: 9
    I waited over an hour and no activity, i removed auto face enhancer, and the load time is now 5 min.
    How do I FIX the rest of the warnings?  I am a newbie when it  comes to the "innards" of the program.
    thanks!
    txt
    txt
    log.txt
    598K
    edited June 2020
    Looking at your second Log-file;
    The file "ePHMDDAlyxSmile.dsf" has a typo somewhere within the code => Reinstall the file and if the error doesn't go away, look for an update or contact the PA. You could try to figure out the mistake by yourselves, but it may be quite difficult as it could just be a comma instead of a full stop or something just as frustrating.
    You can remove the file or rename it to "ePHMDDAlyxSmile.dsf.xxx", which will get rid of that particular warning but unless you remove the character as well, renaming/removing can cause new warnings due to the missing file that is referenced in other files of that character.
    KinsleyBody.dsf... Could be the same thing.
    Alias... No clue
    The morph/file "CTRL_ChRO_Smile.dsf" is trying to find another morph/file "eCTRLEyesClosed.dsf" to change it's value, but cannot find it
    ... The same with the rest of "Could not find", the easiest solution is to remove the file mentioned after "in file :", keeping in mind that if the file is a part of a package / character, the rest of the package / character may as well be in need of removal if removing the one file causes new warnings.
    "Duplicate formula found" = You have the same morph installed at least twice in your data-files, this could be that you have installed the same file twice in different locations (revisions may cause this), or the PA has copied code from a previous morph and didn't change it enough, or even DS may have erraneously written code into a wrong file when updating assets.
    Reinstall the morph, search for duplicates and these don't give you a solution or a clue to the cause, remove the character.
    Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,788
    Alias... No clue
    Aliases are things like expression sliders on the ehad as well as the actor, or hand controllers on hand and figure - having one property appear in two places
    Duplicate Formulas does not usually indicate duplicate files, it's mostlly a conflict with two products using the same name for their different properties. It can also be an issue within a single property, but testing shoudl catch those.
