Supersuite Help
Hi ,
I've installed the supersuite fantasy pack with the Daz installer , it shows in the SW but it wont work ;-(
can anyone give me some hint ? does it have to be used in conjuction with something else ? ..
thank you very much in advance for your time ;-)
  • markusmaternmarkusmatern Posts: 614
    Which product do you mean exactely?
    https://www.daz3d.com/supersuit-fantasy-pack
    This also needs https://www.daz3d.com/genesis-supersuit to work correctly.
  • McRenArtMcRenArt Posts: 67
    edited June 2020
    I have the supersuite fantasy pack ;-) so if you don't have the genesis supersuit it won't work ?
    I think it should be said on the product page ;-) bc I haven't seen it :-)
    thanks for the hint ^_^
    Post edited by McRenArt on
    It shows under Required Products for me.
    ok ^_^ I was actually looking but couldn't see it ^_^
    OK ^_^ Thanks
    So not a browser problem as some do have a problem with that I think because it is script generated.
  • LeanaLeana Posts: 13,498
    Be aware that the shaders presets included with the supersuit are for 3DL and will most probably require adjustment if you plan to use the suit with Iray
    Or render in 3DL, that's okay too ;-)
    I remember when those all first came out, we were buying them just to get the shaders! {suits were a nice bonus}
