Lower position nipple/areola in Genesis 2
Hi.
I want to make a realistic female model with overweight. Have a lot of morphs and characters as a base but my problem is with the areola and nipple. Usually natural big breast tend to be flat and with the areola in the lower area. But Daz models have the nipples and areolas in an upper position.
Do you know any mod, product or trick to lower down the areola and nipple to that area?
Thanks!!!!
  • Canary3dCanary3d Posts: 2,033
    You can get some of the effect you're looking for by turning off limits on the Breasts Under Curve morph and using it in reverse - negative values.  That takes away a lot of the flesh of the lower part of the breast.  Combined with Breasts Natural, Breasts Upper curve, and Breasts Heavy you can make somewhat larger breasts with the areola lower down on the breast proportionately.  In general you can get a lot of useful effects by turning off limits on morphs and using them in reverse.  Click the little gear wheel on any morph and uncheck limits to allow this.
  • iruizapoiruizapo Posts: 3
    Thanks for the answer. I'll try it.
  • nicsttnicstt Posts: 11,715
    I'd look for a character that has larger breasts if possible; if you're render nude or partially clothed you will get the textures stretching.
    Ideally the textures need painting on the shape required when extreme.
  • CybersoxCybersox Posts: 10,001
    iruizapo said:
    Hi.
    Thanks!!!!
    Easy peasy.  ZevO's Breast Control for Genesis 2 Female contains a wide variety of areola morphs and adjustments, including up/down, side to side, size, size x, size y, depth and a number of complimentary nipple morphs, breast shapes.  This product is available at a greatly reduced price as part of a bundle with Glute Control for G2F, and is easily the most comprehensive set of tools for G2F breast shaping on the market.
    THAT SAID, keep in mind that the position of the nipples/areola is in a fixed position on most skin textures, so you may have to adjust that placement as well for optimum results if you're really pushing to an extreme position.  Fortunately, that's pretty easy to do with any photo-editor just by making a duplicate of the torso textures and using the clone tools (and there are also vendors at Renderosity who sell stand-alone nipple textures.)  To get the best placement, DAZ script wizard mcasual has an excellent free script called Tailor's Chalk that lets you set ideal guidelines
