Genesis 3 Female figure properties won't reset
I've created a character (using FWSA's Mable HD), somewhere along the line I can't reset any properties with an alt-click or with a shaping preset.  If I select the property and manually adjust the slider or type in a value (even zero) that works.  It's with this character, closing Daz and re-opening has the same results.  Load a fresh G3F and things are OK.
What's happened and how do I fix it?
  • Richard HaseltineRichard Haseltine Posts: 111,390
    If you loaded a  character preset then its values will be set as default - you could zero the figure (or its shape) and then, if you want, memorise that (both have sub-menus in Edit>Figure).
  • GatorGator Posts: 1,320
    Thanks Richard, I found the problem - some wonky Zbrush morphs.  Not sure what I did, but I messed something up.
